sparkync
- North Carolina
I have a "Main panel" with a sub panel directly beside it.  I'm having to move a "240 volt" dryer circuit out of the "Main panel" into the sub panel in order to make room for a "generator main breaker" at the top of the panel near the 200 amp "Main breaker" for the "inter-lock" kit.  By code does the neutral and equipment ground wire, have to be moved also?  The Main panel is very "congested" with wires, making it hard to "access" the neutral and ground wire.  I know the circuit will work of course, bur what does the Code say about it.  Thanks
