JustinMiller said:
What could this do..there was a fire at the residence.
Every singl light in the house was turned on as well as the airconditioner.
everything seemed to be fine. I am expecting foul play.......
We have to tread lightly here. If indeed there had been a fire, and if it is suspected that the electrical installation might have had an influence in getting the fire started, then the members of this Forum are not permitted to provide any information or advice that might be used in a legal proceeding. We are not "expert witnesses," and we do not give "expert advice." Nobody has permission from the owner of this Forum to use the information posted herein as supporting evidence in a court of law.
That said, I will concede that switching a hot and a neutral from the incoming utility to a main service panel is bad. But could it start a fire? It is possible? The first time you turn on a single phase load, you will get 240 volts, and not 120 volts, going through the load. That could push enough current through the load to cause it to overheat, but depending on the load it may or may not trip a breaker. If the load is a light bulb, the light would probably explode. But that would just cause a mess ? glass all over the floor ? and that would be the end of that event. If the load is a heater, the effect might be worse. If a large number of loads get energized at the same time, such as when you first turn on the service, who knows what might happen. If you want to know, you need to hire a forensic engineer or an electrical contractor with experience as an expert witness.
