Neutral at 3-Way Switch
JRC
New User
New Jersey
Engineer
I am installing a new light at the bottom of a basement stairway. I plan on bring power from the panel to the 1st switch. From the 1st switch, I will run a 14-2 to the light. Also from the 1st switch, I will run a 14-3 to the 2nd switch but will wrap black tape around the white wire indicating that it is no longer neutral. Is this per code? I have seen statements before indicating that per a recent code change, a neutral wire must be present at every switch, even if it is not connected.
tom baker
Bremerton, Washington
Master Electrician
The requirement to reidentify the grounded conductor as ungrounded is not a recent change, its been a requirement for about 15 or more years
