I have an existing 480V, 3ph, 3W panel and I am needing to add a neutral. Also, there isn’t enough room in the panel to add the neutral bar. Is it against code to have an enclosure set beside the 480V panel just for the incoming and outgoing neutrals? If so, any other ideas on what I can do without replacing the entire panel?
