dwilliamsx6
- new hampshire
- renovator
hello, commercial building built in 1979, first panel off meter is a 400a load center with three 200a breakers, each supply a subpanel in different parts of the building. upon inspection it was found that the largest of them, a square d qoc40mw225, which looks original, has only 3 wires feeding it, the neutral bonding screw is installed, grounds and neutrals share the buss. am i wrong or should this be unbonded with neutrals and grounds separated and a fourth wire for the ground buss? or was this okay in the 70s? thanks
