Here is the scenario.  The voltage at the lighting panel is 480/277 as it should be.  When a load as small as one light fixture is added the following test results are observed;
A phase 0 Volts to ground
B phase 277 Volts to ground
C phase 277 Volts to ground.
The panel is the load/secondary of a lighting inverter. Problems like this always seem to be the neutral. Will you help me to articulate what causes problems like this, with wonky voltages happening because of neutral issues? Thanks y'all.
