omz
- Texas, USA
- Electrical Engineer
Is neutral wire in a 3 phase system considered a grounded or ungrounded conductor?
The literal answer is: It depends on whether it is grounded.Is neutral wire in a 3 phase system considered a grounded or ungrounded conductor?
I think it has to be groundedIs neutral wire in a 3 phase system considered a grounded or ungrounded conductor?
Strictly speaking, a "neutral" wire is one with no current flowing in it. But that only happens in a perfectly-balanced circuit, which never happens in real life.
The answer depends on what kind of circuit it is. In an old corner-grounded 3-phase delta, the grounded wire is one of the three conductors, carrying the same current as the other two and anything but "neutral". But because it's grounded, it's required to be color-coded white or grey, and the words "white" and "neutral" are often used interchangeably by people who are less persnickety than I am.
The same would be true of a single-ended single-phase American/Canadian 120-volt circuit. One of the two current-carrying conductors is grounded and white, but not neutral.
In a three-phase Y that only supplies three-phase loads, there isn't any white wire or neutral conductor. But the transformer centertap is expected to be grounded. (most of the time -- exceptions exist)
In a three-phase Y that supplies both single- and three-phase loads, the white wire isn't neutral because the single-phase loads assure that the three phases are unbalanced, and consequently, the unbalanced return current is flowing in the white wire. But the transformer centertap (white) is required to be grounded.
The NEC requires it to be grounded.
The NEC also states that, for certain specified voltage ranges, if there is a neutral conductor in the source circuit it must be grounded.
" . . . than I."Wow. There's a person out there who's even more persnickety than me. What were the odds?
:lol::lol::lol:" . . . than I."![]()
Of course; context matters. I use these for examples:It depends. If you consider "than" to be a preposition, then "me" is correct.
If you consider the statement to be an ellipsis of "..than I am", then "I" would be correct.
Seems that would be an important factorI like this answer.
Most cases it does need to be grounded.I think it has to be grounded
