Neutral Conductor Sizing
teej
Is it ever permissible to downsize a neutral conductor in a typical 120/240 V 3 wire service installation? For instance, can you have two hot legs sized at 2/0 and make the neutral 1/0? I was told by someone recently that this was permissible, but I don't see that in the latest NEC. If it isn't allowed now, was it ever allowed in the past?
Re: Neutral Conductor Sizing
See 220.61 of the 2005 NEC and 220.22 of the 02 and earlier.
Roger
Just remember that the service grounded conductor must also serve as the effective fault path of any ground-fault that occurs on the system. Also, this increase in circuit resistance will place more normal operating current on the metal parts and grounding systems.
I don't know why the NEC contradicts itself on this matter. :(
It probably has to do with the long-term flow of normal current, and the (hopefully) short duration of a ground fault.
