I've read in detail all the posts about when you can and can not reduce the size of the grounded conductor (Neutral) . . . what I can't find is reassurance that once I make the decision about the unbalanced neutral load that I need to size that conductor based on:
Table 310.16. (It lists USE cable but not SE)
OR
Table 310.15.B.6 (for 3-wire Single Phase Dwelling Services; including SE)
Is there some distinction that leads to the use of 310.16 as opposed to 310.15.B.6?
OR
