In a typical resedential service in my area you have a imc riser pipe out of the top of the meter can. The utility drops power overhead. The neutral is bonded to the meter can. The messanger/neutral is tied DIRECTLY to the imc riser pipe. A 3-wire cable than feeds the main disconnect where the main bonding jumper is instaled.
My question is it seems to me that a small amount of neutral current would flow on the meter can and imc pipe, is this normal or OK?
