The strap or screw are tested and listed with the panel(s) they are designed for. Also consider there is virtually no length to them where when you apply the conductor in the table it doesn't really have any length restriction either, which does add some resistance after you get some length there.Ok. Thank you.
That's what I would think YET currently and approved is a little thin piece of metal strapping. Or others are a screw ????
Doesn't make sense but I'll bond it with the sizing of that table. Thank you again
