Randal Vincent
I've come across a problem I can't solve. It seems I?ve got a potential difference between my ground and grounded conductors. I have a small sub panel feeding my pool (220 30amp. w/insulated ground back to main panel.1 circuit gfi breaker 20 amp for pool pump. 1circuit gfi 20 amp for 2 120 volt pool lights. I noticed when I touch the neutral bar and ground bar with my screw driver I get sparks. It seems to happen with either load running(pool filter or lights). At the sub panel, when I check for voltage across hot to ground I get about a 3 volt difference from hot to neutral. I also measure 3 volts from the neutral bar to the ground bar. I know my sub feeders are good. I know all my connections to all 3 loads are good. I've also checked all ground and neutral connections.
I know the neutral and the ground wires are connected to the same point in the main panel, but I can not understand why I would see a potential difference in them at the sub panel. Any comments, suggestions, or explanations are most welcome.
Thanks,
Randy
Thanks,
Randy
