In a discussion on another Forum. Inverter being supplied with 230 volts no Neutral but EG wire. Outputting 115/230 vac as a transformer might with a center tap to source the 115 volts. They are calling the center tap, Neutral I contend that its Not a Neutral until its tied to the Main ground lug at the service panel. Attaching it to the panel EG does not qualify, opinions?
Yes I have Mikes 2020 PV Code book, the Illustrated one. Retired Master in Iowa
