agubaira
- Valencia, Venezuela
Hi everyone,
I´ve got the following connection scheme:
3 phase delta wired Generator --> Transfer Switch --> Main Panel --> single phase Step Down Transformer (220 to 110V) --> Load
(The reason to use a step down transformer is to reduce cable gauge because of voltage drop)
Now, the transformer is fed with 220V line voltage, no neutral. How do I go about getting a neutral at the secondary and where must it be bonded to ground ?
Thanks
Thanks
