wayne123
- North Carolina
I am installing a service on a house that is 400 amps. The customer bought a 400 amp manual transfer switch to supply power from a generator when the power goes out for extended time. I mounted a 400 amp meter can, then the TS then two 200 MBP. The transfer switch has an isolated neatral block in it. my question is since the neutral is bonded to the ground in the meter how do I go about grounding the transfer switch? The panels are connected together with pvc that leads to a trough under the TS and the 2-200 amp panels.Also there are no metal water pipes in the house and the AHJ told meto just drive two ground rods, so the ground I am speaking of is that.
