Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
Basement lighting. Basement is utility space and will never be finished. There is only 1 entrance/exit with a SP switch for some of the lighting in the basement. This switch does not control the lighting for the stairs going to and from the basement which is switched separately.
Code says neutral not required if space is "not habitable" 404.2c.
Do you agree that a neutral in the sw. box is not required?
