Code section 404.2(C)All switch boxes need a neutral even if not needed, correct? If so, which article in code book?
I'm gonna have to read up on that. I'm pretty sure if the wiring method is conduit or there is an accessible way to feed a neutral then. It doesn't have to be present.Code section 404.2(C)
Good move,, the way the op was worded I thought he was asking for the article that agreed with the post..I only gave the section so that the OP will read all of it.
