If you have two panels side by side one fed from the other. Can you land the neutrals for the sub panel circuits in the main panel?
Why would you want to?
In such a case, the 2nd-panel neutrals have to pass through the same nipple as its feeder conductors.I have seen this done with a two section panel and the neutral bar in only one section.
That happens when the small generator panels are used.
Yeah. That is very wrong.You mean not like this: :roll:
