jim sutton
We have a situation where we are installing an automatic transfer switch on a generator. We are running two feeders in conduit from the loadcenter. The existing feed to this loadcenter is spliced to the feeder to the ATS and connected to the "normal lugs". The other feeder connects to the "load" lugs in the ATS and then to the main lugs in the loadcenter. We have been installing a neutral conductor in each conduit. We have been told that this is unnecessary, that the neutral is only needed in one feeder! I dont agree and have been looking for a code reference. This is not a parallel feeder because the conductors are not joined at both ends.
I remember being taught that the neutral should be close to the same length as the phase conductors due to overheating problems. At the time we were discussing long switch legs, not parallel feeders.
Any thoughts, comments or code references to support my position? Or am I wrong?
Thanks in advance!
Thanks in advance!
