Whoa! Not that simple
There are many ways for the conductors to be installed: For flat (horizontal crossarm) installations: 3 phases on the arm and neutral below, all 4 wires on the arm, 3 phases on the arm with neutral above (lighting prone areas). For vertical 3-phase the neutral is usually low, but could be on top in a high lightning area. Same for single-phase or V-phase with one or two phase conductors; the neutral can be on top but is generally on the bottom (western US).
The only ay to tell for sure is to find out which of the conductors is grounded every now and then. That is the neutral.
There are places that still run 3-wire systems with no neutral at all.
