busman
- Northern Virginia
- Master Electrician / Electrical Engineer
Does anyone know what the last code cycle was that allowed the installation of new neutral grounding for ranges/dryers. I have a house built around 1980 and it has quite a few 3 wire (SEU cable) circuits and since I'm changing the location of the disconnect, the panel will now have neutral/grounds separated. I'm looking for a good way to determine if the bare wire is a neutral or an EGC without going to each piece of equipment and opening it up.
Thanks,
Mark
Thanks,
Mark
