hardworker
I am working in a commercial building with older wiring. I am relocating circuits from an old panel to a new panel. This particular small subpanel has 3 circuits and only 2 neutrals.
I surmise 2 of the circuits are sharing a neutral, so I take the following steps to determine which of the two circuits are sharing a neutral.
I remove one neutral conductor from the bar to see what goes out. Nothing happens. All three circuits are still hot.
I put that neutral conductor back on the bar and remove the other neutral. Nothing happens. All three circuits are still hot.
I remove both neutral conductors from the bar and everything goes out, except one circuit has a slight amount of current still flowing, because the lights were still on, but very dim.
The wiring is in EMT. This old wiring has no ground conductor.
I have not yet traced all the wiring.
What would you think is the problem?
