RICHRICH36
- Florida
I have a strange situation in which on a strictly "theory" point I can not understand the need for the neutral on the line side. I am wiring three buck boost transformers to boost from 208 to 240. There is no neutral required on the load side (which you can not get with buck boost's anyway). I have attached a copy of the wiring diagram. Note that the ground and neutral look to be bonded at the transformer but Acme point blank said that this is the building bond and do not under any circumstance bond at the transformer.
[/IMG]
