220.61 states that the neutral load shall be the maximum unbalance of calculated between the neutral conductor and any one ungrounded conductor.
If my panel voltage and capacity is 120/240VAC 400Amp load center and the loads connected are all 2 wire 240Volt appliances with balanced current on the 2 ungrounded conductors ex. electric heaters and water heaters what do I use to size my neutral to the panel?
