WSMITH49
New member
- ringwood,nj 07456
I am running a 480 volt / 60 amp, 3 phase feed, with ground, to a motor control panel located outside of building. Customer wants to install sub-meter (Leviton 2000), the panel does not require a neutral, nor is there a provision for one, the sub-meter needs a neutral to operate, (5 amps). What is the smallest neutral that I can run with my #6 feeders? Thank you
