I have recently seen several different proposals for the installation of some auxillary transfer switch installations. Most of these were 3ph. 4w. 277/480v. installations. Some of the engineers specked the xfer switch to be a four pole (switching neutral), others only had a 3 pole xfer switch specked. What would be the pros and cons of switching the neutral or letting it remain solid? Thank you.
