brantmacga
Señor Member
- Georgia
- Former Child
I had a situation today that I haven't encountered before:
Job was to install track lighting opposite of existing tracklight. With the circuit off, I found the switchleg in the attic and started to make a tap. When took hold of the cable end going to the existing light, I got shocked. I only had my wiggy in my back pocket and took a quick reading. The cable end going to the switch was dead as it was supposed to be. The cable end going to the light measured just under the 120v line, so lets assume it was somewhere around 100v (it felt weaker than 120v but I could be wrong).
I went back into the room where I was adding the light. I took the bulbs out of the existing track light and had the same voltage reading. Below this light was a receptacle with a computer plugged in through a surge protector (apparently on the switch leg). I uplugged the surge protector and checked voltage at the lampholder again: nothing. The voltage was coming from the surge protector itself. It was called a Panamax Max 4.
Was a capacitor discharging discharging and passing through and MOV or something? I haven't seen this before, so I'm just unsure how it got between the neutral and ground.
