Eye yi, yi! The neutral is a current carrying conductor; it?s supposed to have current. The ground is not a current carrying conductor; it?s not supposed to have current. Therefore there will be a difference at any given moment between them.
Do not misuse the ground, it has nothing to do with returning current, AC or DC, if a return path is needed bring a conductor along for this purpose.
Conversely to this the neutral (grounded conductor) is not ground it only happens to be connected to the ground at the source, it should not be connected to ground past the source again to eliminate any parallel neutral current.
The neutral has a duel purpose at the source, 1) to enable returning current of its circuit, and 2) to enable a ground fault path from non-current carrying items (metal frames) to source, it enables extremely high current that will in turn operate overcurrent protection. Past the source the bonding enables ground fault path not the neutral.
