If I run a circuit from a j-box inside to a disconnect outside and then back inside to the same j-box with all the conductors in the same piece of conduit (say 10' long) between the j-box and the disconnect, do you still need to run the Neutral out and back in even though the Neutral doesn't get switched? Or can you just run your line and ground conductors out the disco?
