Neutral Wire used in some light switches
diitto
New member
Rio Vista, Ca
I have outdoor lights that are currently powered by in indoor, simple on/off switch. I want to replace that switch with a timer/switch so the lights can come on automatically at night and go off in the morning. I notice that some of the ones I see to buy say "no neutral required" while others say the opposite, "neutral required".
Why do some of these switches require a neutral be present and wired to the switch??? What would be the purpose of the neutral in those that require it? Why would a switch EVER need a neutral wired into the circuit???
thanks... diitto
thanks... diitto
The timer would/may need a neutral. Some switches were using the EGC as the return path since UL was listing them as allowing it if the current was in the mA range, but the NEC was in conflict. The listing and the NEC has changed to address this situation.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
