I have a 480primary 120/240 sec. transformer feeding a lighting panel wired up 240v 3 wire system, vendor sent prefab flex with 3 load wires 1 neutral wire and 1 ground wire. I shared the neutral wire by putting two hot on one side and one hot on the other side. This is a 12 circuit panel term. it by circuit 1--123 aba circut 2 bab
circuit 3 aba circuit 4 bab. my neutral at the transformer is bonded to ground, the breakers I used are 20 amps and used all #10 stranded wire for my lights. Is the installation per NEC
