papa smurf
Does the neutral wire ever have voltage on it.
Usually when you didn't want it too!Does the neutral wire ever have voltage on it.
That is true only for the neutral at the point where the main bonding jumper is located or for a neutral that is not carrying any current. All neutrals that carry current will have a voltage to earth that is equal to the voltage drop on the neutral conductor between the point of measurement and the main bonding jumper.the AC voltage on the "neutral" (grounded) conductor is zero with respect to earth ground :smile:
Yes. There will be a potential from the current carrying neutral to the normally non-current carrying grounding conductor. The voltage drop will make the difference as well as the difference in sizes of conductors. As stated before, the voltage will be low but it will be there. It all depends on how much return current there is on the neutral and the other parameters.Does the neutral wire ever have voltage on it.
Yes it can have a few volts with reference to ground.
Depending upon its distance from the source and the load on the entire system it would not be unusual to measure 1,2 or 3 volts on a large commercial building with respect to ground from the neutral.
It is simply voltage drop due to a combination of the load and the resistance/length of the wire. This will also sometimes create a small spark/arc when you touch it to ground.
This used to mystify me when I was a first year apprentice in 84 and hardly anyone could answer correctly what caused the spark/arc.
