hbiss
EC, Westchester, New York NEC: 2014
- Hawthorne, New York NEC: 2014
- EC
I just watched a You Tube video by a plumber who was troubleshooting some thermostat and zone valve problems. He found a dead short on the wiring off the 24vac control transformer which blew the internal fuse. So, he replaced it and in doing so checked for 24v on the secondary screws to see that it was working. But what I never saw anybody do is measure from each side of the secondary to ground, noting that one side is higher than the other and call the higher side the "hot" and the other "common". He actually marked H and C on the transformer with a Sharpie.
I submit that any voltage to ground is a phantom of his DVM since the secondary is floating. Secondly, what does it matter?? There is no reason for a H and C.
-Hal
-Hal
