Electric-Light
Some CFLs say it on the package, some don't.
FEIT brand shows the same count-limit regardless of size. Both the 13W and 26W version warns:
"Never use more than 25 lamps per 20A branch circuit".
These use bulk-storage rectifier front-end and look the same as switching power supply to the line. Measured power factor is 0.55 and I'm guessing THD is between 100 and 130%, pretty typical for bulk storage rectifier front end load.
so, the 13W version uses 24VA, which basically means 5A/600VA limit per 20A circuit, which doesn't make sense, because higher power switching power supplies, such as LCD TVs and computers can exceed that amount in single device.
What is the basis for this limitation? Is there anything in the code about this?
