I have a design question. With so many new large houses, most require 400 A service. How does a 400A single phase, 120/240 service for the residential application look like when the service outside is some distance away from the inside disconnects and one would need an outside disconnect.
The main service is underground, meter is outside against the house, and the two 200 amp panels are inside the house about 30? away. I can't find a meter set with a 400A MCB or one meter with 2-200A MCB's on it. Should I consider a 400A, 1PH, FSS?
