New Central Vacuum unit tripping breaker intermittently
tsramkumar
New User
Aldie
Professional
I recently had an MD 715H central vacuum system installed ( 14.9 amp max / 120 volts.)
It is on a dedicated circuit with a normal square D breaker 20 amp breaker. The power unit is in the Garage on a GFCI receptacle.
After a few weeks of being installed, every time I start the unit for the first time after being not used for a couple of days, after about 30 to 90 seconds the 20 amp breaker in the panel trips. Then after resetting the breaker, I could vacuum all day long without any more trouble. Sometimes, it may trip more than once in a single day.
Not sure what is causing the tripping. I had an initial conversation with the manufacturer support and they said i had to remove the GFCI and make it an ordinary receptacle for the dedicated circuit. I am hesitant to do this as NEC requires GFCI for all outlets in the Garage.
I came across a similar issue reported by another user on a different forum and one of the responses was to use High-Magnetic Breakers to Power the unit (Square D (#QO120HM) for a 20 amp circuit ).
This nuisance tripping is annoying and not sure what the resolution is. Any suggestion is greatly appreciated.
This is not an issue we can assist you with, but rather it’s a manufacture/product issue.
The GFCI is doing its job protecting against leakage current
I'll just comment on this part; your intuition is good on that. They are recommending that you violate the NEC, that's never a valid strategy.
But also, if the BREAKER is tripping and it's not a GFCI breaker, the fact that it's on a GFCI outlet has nothing to do with it. So Tom's point is valid; this is not an "electrical" problem as much as it's a product problem, stick to your guns with the manufacturer.
