New Circuit Grounding
zooby
Indiana
maint. electrician
Circuits pulled from OSRP to RP3.
These new circuits intercept below RP3. RP3 is not gen backed panel and we need the fridges and freezers backed up. I have pulled the "existing" four circuits(in RP3) down into the trough below RP3 and are tied onto the new circuits from OSRP. There is a #10 grn pulled in with the four circuits.
My question is.....Do these circuits now tie in only with the #10 brought over .....or can the #10 tie into the ground bar in the panel? Thanks much!
Thanks Roger. I was getting hung up on "all conductors....same panel". In this case, I DID need to pull a ground(grn) along with them right?
Yes, unless you were planning on using the metallic raceways as the EGC.
