New code requires a metered disconnect
Patdarock
Nj
So I am going to do a service since the new code, I’ve done plenty of metered disco combos using the combo with 200amp breaker.
1. I was wondering is there a combo that is a fuse less disconnect.
2. I usually do a main lug panel now being that I have a 200 amp breaker as my main disconnect outside. But this client wants a 30 amp plug outside for standby genny. So now having to need an I teocm for said plug(30amp breaker) I can’t see how I’d do it without having a main breaker panel. But seems redundant and waste of money.
Just looking for suggestions and discussion thanks in advance
Im trying clarify the writing of 230.85
Does the disconnect need to be a ocpd type
Cause if not I guess I could do meter base to useless outdoor disco to 200 amp main breaker panel to accommodate interlock , that would be ugly on a house tho imo, these codes are getting ridiculous if u ask me
Some areas have using outside meter combos for years as they can pull a ckt for hvac outside unit. But the code language is not 100% clear, there are many posts on this, do some research here to help
