joedreamliner787
- CT
- Electrician / FA Contractor
Hi everyone,
Have a large home that will have an attached guest unit (has its own kitchen, washer/dryer etc. Panels A & B will serve the main house and panel C will be the sub-panel in the guest unit area. When performing the optional method calc do I perform the calc on the entire sq ft of the main house including the guest house or do I perform two separate calcs (1 for main house 1 for sub (standard method) and then add them together for the service?
I will add there will be a 400 amp service into the meter - x2 200 AMP Service rated ATS and each of the ATSs will feed 1 200 AMP Panel. Subpanel C will be fed from panel A on a 100 amp breaker.
Thank you in advance
