james_mcquade
My grandmother left me her house & farm and we have moved in and almost finished remodeling. the house has (2) 100 amp plug type fuse boxes. we were having a central unit quoted when the contractor said the service would not work for the central unit. since we want to consolidate both services anyway, thats ok. while i am a consultant, my expertise is not household wiring.
How do you compute the house load requirement?
My concern is the 200 amp service the contractor wants to put in may be pushing its limit when you apply the safety factor.
we have the following: 1600 sq ft house with attic, 3.5 ton ac / 10kw heater, the usual household appliances, a 2hp 220vac in ground water pump, a welder, open carport, open front porch area.
thanks in advance,
james
thanks in advance,
james
