Is it a requirement that a sub-panel located in a detached garage have a main circuit breaker, or does a 50 amp branch circuit breaker in the house pass as a disconnect means? (It's 80 feet away) The sub-panel in question has 4 circuit breakers installed but space for 12 1" wide circuit breakers.
Also, is it permissible to use #6 wire with a 50 amp circuit breaker for a sub-panel rated for 100 amps?
I have an existing 1" conduit under a large driveway that we're trying to utilize for this sub-panel and it's size is limiting the selection of wire gauge.
