When did manufacturers change from GREEN "OK" indicator light to RED "tripped" light on GFCI receptacles? Was there a change in NEC or UL that required this change? I haven't decided if I like the new concept.
Before, you knew if you had a GREEN light the GFCI was ready to go. Now the only indication you get is the RED tripped, which you can figure out pretty easily when the appliance you have plugged in doesn't work.
