For the past two years, I've been doing work for a large church that has slowly been installing new furnaces and ACs as they can afford to. Nothing special, just pulling out the old inefficient units and installing new energy-saving ones. It's a simple process from my end.... just disconnect the old units, let the tin-knockers do their thing, then re-energize the new units.
Each furnace (there's 14 in this room) is on it's own circuit, and there's 6 'general' circuits I've used to power up a GFCI next to each furnace for service as well as a condensate pump.
Yesterday, I got word that the GFCIs installed to date are now tripping en-masse. Each one (11 have been changed to date) has a condensate pump plugged in, and it's hard to image them all having a ground fault at the same time. When the GFCIs trip, the pumps don't work, and the furnaces shut down because there's a sensor in them that detects the back-up of condensate.
There's three furnaces that supply the sanctuary that are 'twinned' to one t'stat, and the other day all three GFCI's (2 circuits) tripped together. There's another two that are 'twinned' the same way. No, the furnaces ARE NOT on the GFCI circuits, nor are they GFCI protected. They are all on their own, dedicated 20a circuits.
But the facilities manager is saying that suddenly, several GFCIs are tripping, and they're noticing because it's winter and suddenly an area is 56° or so. Sometimes just one or two, but sometimes 6 or 8. They reset the GFCIs, the pumps kick in, the furnaces turn on, and everything's fine..... until they start tripping again. No apparent rhyme or reason. If it's defective GFCIs, that's would be difficult as the GFCIs have been purchased as needed over the past two years.
Any ideas on what could be causing this? I
