When I run a new grounded circuit to a new location for a range that has a flex cord with no separated ground, am I required by code to replace the pigtail with a four prong, and separate the ground from the N at the appliance? Or, according to 250.138 B, is a Tek Screw to the frame through a ring terminal connector on 6 feet of #10 stranded green wire which is snuck around the recpt. cover plate and attached to the #10 EGC, a proper solution? Then, if so, again, am I required to separate the bond in the appliance to avoid objectionable current on the ground?
I was planning to use a plastic double gang cut-in for the outlet box, so no grounding potential exists through the plate screw.
