I have a great project that I am about to start. It is a time and materials new resi. home - big money - approximately 6000 sq./ft. Unfortunately it starts asap and the cold weather is here. I am trying to configure the service and any insight to an easier way would be appreciated. Will be underground service - 400 amp (2 200 amp panels / 320 amp can) which will need to go to panels in mechanical room which is at opposite end of home from where service entrance will be. I am planning on one of two scenarios - #1= 320 amp meter main on service pedestal (fed via 2 sets 4/0 AL) at property line with 2 200 amp breakers and 2 sets of 4/0 AL run underground to 2 200 amp panels located in mechanical room. In this scenario I will hit ground rods at meter main and have a #4 CU ground wire run with each set of conductors to their panels. At panels I will hit each with #2 Cu to water main and also hit UFFER ground to one of them. My second scenario consists of me mounting a 320 amp meter can on outside stone face of house supplied by 2 sets of 4/0 AL. Then supply each 200 amp panel in mechanical room with a separate underground run of #4/0 Al grounding service at this point.
So what is the verdict? House is one level and over 160' long built into side of mountain.
