alsant
- villa park il.
am i in the ball park with charging 1400.0 for service upgrade for two bed ranch
What size service?
Besides what others have said, also keep in mind why was they wanting the upgrade, if it was because they had over loaded circuits and was blowing fuses and tripping breakers, then you have to let them know that just upgrading a service will not fix these problems, I have done many upgrades from old 4 circuit fuse box, that had all 14 AWG in the house, and by code these wires had to go on 15 amp breakers, so some times the problem can be worse when you leave if they were using 30 amp fuses, if you cant up sell new circuits to areas such as the kitchen, baths, furnace, and splitting up any other heavily loaded circuits.
There are many non-electricians who think is all you got to do is supply more power and the tripping will go away.
The majority of heavy ups are for new heat systems or they are converting from LP or natural gas to all electric.Always good for additional work.
90% of our service up grades are the result of services that turned into rust buckets, or poor cable riser installs, when I hear heavy up, I have to ask does the guy using it know what he is is doing? in over 40 plus years I heard that used on the net a few times, another day another thread.
Who's converting to all electric heat? It must be realtive to climate, because up here electric heat is only very limited. Our heating season is longer than our friends to the south, but the money here is better spent on replacing an inefficient gas or oil furnace or boiler with a new high efficency unit. Service upgrades are used more commonly for added circuit capacity, and in conjunction with the large addition market. We haven't done a 100A install on a new house in at least 5 years, and we don't even offer it as an upgrade anymore. Going market price here for a "standard" 200A upgrade is $2000 with the customer obtaining the permits. To get the work we run at around $1650 and pray for an upsell or change order. At $1400 you may be getting the work but are you selling yourself short? Call some local electrical contractors and ask for a price on a 200A upgrade and see how competitive you are.
WOW you had the net 40 years ago.
"We were so poor, the whole family had to share one pair of shoes."WOW you had the net 40 years ago.
"You had feet?!"
Good plan. I'd go with that....... not
Since you quoted the entire statement, clarify what you wouldn't go with. And being as you live on an island in the ring of fire, I wouldn't imagine heating bills are cripling your budget. The average daily temp in Honolulu in January 73 degrees, in Newark NJ 31.3. I'd say we have a higher heating demand here. A couple years ago we compared two houses, same model same developement, one all electric baseboard with individual room control, and one with a 2 year old gas furnace rated at 97% efficient with a total system efficiency estimated at 80% by the heating contractor with 2 zones. We did the power work for both and got everyone on board to see what the result would be to end the argument up here.The difference? Electric house cost an additional $85 per month in heat on average from October 15th 2007 to March 15th 2008 over the gas house. Now the entire observation was unscientific and there was no true control to say it was a perfect example. But when neighbor A talks to neighbor B and the numbers are that far apart, electric heat isn't a good sell here. In a shorter heating season with a lower demand, maybe. But not here.Good plan. I'd go with that....... not
