Short.Circuit
I've bought a couple Murray residental panels, 100A & 200A. 1 of the nuts that bolt the main breaker onto the bus was loose. I also removed a hex screw part of the lug & check the phillips screw connection underneath & that wasn't tight enough either...
You guys ever check to make sure a new panel is put together properly, as in the tightness of the lug connection, etc? I'm glad i caught this before I installed it...
