goldstar
- New Jersey
- Electrical Contractor
I'm convinced this only happens in New Jersey. This woman's electric service was in extreme need of an upgrade and the siding guys made it worse (see if you can find the SE cable). The poco insisted that she have her service upgraded. This residence is in a lake community in northern NJ. Years ago people purchased property up here, built their own houses and did their own electrical and plumbing work. I haven't opened this make-shift enclosure yet but it's vinyl siding with an aluminum cover. This is an old 60 amp, 240 volt service. The second meter socket was specifically used for the 30 amp electric water heater where the HO was billed at a reduced rate :
Double meter enclosure (siding guy style)
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Double_meter_2.jpg
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/Double_meter_1.jpg
Working meter
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/live_meter.jpg
Blank socket
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/empty_meter_socket.jpg
Poco attachment
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/poco_attachment_1.jpg
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/poco_attachment_2.jpg
Buried SE cable in roof tar
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/SEcable.jpg
First of 3 sub-panels all tapped off the main lugs and unfused.
http://i87.photobucket.com/albums/k130/goldstar13397/New meter enclosure/1st_sub_panel.jpg
This one is lucky enough to be in the basement. The main panel is on the 1st floor in a clothes closet. Now, remember I said this was a 60 amp service. All the branch circuit fuses are 30 amps (irrespective of the wire sizes). I'm guessing that they just got tired of the 15 and 20 amp fuses blowing all the time. There's also a 60 amp sub-panel with a 30 amp, 2-pole breaker for the water heater and a 50 amp, 2-pole breaker for the electric range.
This is going to be a fun job if I get it - but it ain't going to be cheap.
Working meter
Blank socket
Poco attachment
