cmaki
- sheboygan, WI USA
So where I work we have an 1750RPM motor going into a variable speed pulley into a gear reducer to the final output shaft. I believe the motor is starting to go and I was tasked with looking into a different way to run everything. My first thought was a direct drive. Motor is 480 3ph. problem is the final drive is spinning between 50-70RPM. I was going to put a small freq drive on it so we can still adjust the speed . (and we need to) Can motors spin this slowly for an extended period of time? It would be running for about 8-10 hours per day 5 days a week in a very dusty woodshop.
My next thought is to run pulleys to the reducer so the motor can still spin at a higher RPM. Is there an advantage to either way?
(admin if this is in the wrong forum please move)
