831
- South Jordan, Utah
Define "expensive".bphgravity said:The are too expensive as compared to like terminations.
831 said:Define "expensive".
It's hard to beat a wire nut.Extremely cheap and very reliable.bphgravity said:My point is that unless there is a speicific application where the features of this connector are needed, the additional cost over wire nuts and other low cost connectors is unnecssary.
Thanks for the idea! I always feel guilty cramming stranded OFC speaker wire into a marrette, even though I know myself that you could hook everything up with NM and not tell the difference.ed downey said:I have the same type of connector to terminate the 14 Ga Speaker wire on the Russound Whole house Audio system.
-Ed
I twist first master even though the manufacture says I don't have to for it is written, on what everHighWirey said:"It's hard to beat a wire nut. Extremely cheap and very reliable"
But, Grasshopper, do you twist those wirenut conductors, or not twist' em'
Merry Christmas Everyone, and Best Wishes
831 said:
jrannis said:I like to use this type of termination in fixtures like hi hats where space is tight and have mutiple terminations
iwire said:Look again at the picture.
I bet the ones you use do not have the lever to release the conductors.
